- Jan 18, 2010
- Residing in Wicklow Ireland
I ran compatible refill carts and ARC chips from the get go, and they worked quite well, but because I wasn’t using the printer that often I had to run a cleaning cycle if I want to be sure of 100% clear nozzles.Glad to hear you love it....may I ask how you are refilling yours?
I went back to using OEM carts and the difference was huge, no more cleaning cycles were needed because the OEM carts preformed far better, but I did have an overflow issue when I over filled black, I printed a dozen sheets with a black image and solved the problem..
The Maxify is a tuff Auld girl and can take all the abuse you can give it, I’m using HP inks in mine..
