- Dec 27, 2014
- Germany
there are several physical parameters which are relevant, one more is the temperature at which the ink starts boiling - the principal mechanism to get the ink drops out of the nozzles - bubble/thermal printhead. I remember that I tested some Epson refill inks - the colored ones - not black - I swapped those in an IP4200 as I remember , and that didn't print at all - not more than just a few lines. Please be aware that the black pigment ink channel of Canon printheads runs with a higher droplet size than the color channels , and those use even several nozzle rows for different droplet sizes.
If you want to substitute the pigment black in the G-series printers with an Epson dye black it's fine if it works for you, but be aware that the Epson 664 inks and the G-series dye inks both don't have a good UV/fading performance.
