- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
Because my Epson R3000 has this terrible problem of ink leakage because of the design flaw of the PK/MK motor, I am thinking of buying an Epson P800 printer. Hopefully the PK/MK problem is much much less or almost none existing and also having a lot of Inktec Powerchrome K3 pigment refill ink, which I unfortunately cannot use in a Canon Pro-1000 printer due to the ink formula.
Can someone confirm if the existing resetter for the Pro-3880 can be used to reset the cartridges of the Epson P800 printer, because the maintenance catridge seems to be same ?
The refillable cartridge option is second: there seems to be a problem with certain versions of the P800, allowing the auto reset chips to be used only once. I presume the EU-version is not affected by this problem.
I will first try to repair my Epson R3000: if this does not succeed I will throw it away.
