- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Dear fellow refillers,
I am really stuck with a problem I will try to describe.
I tried to clear the printhead of a Canon MX885 where the cyan and magenta were severily clogged.
Everytime when after bathing the nozzle check was OK, after a few pages the clog was there again.
I suspected the ink (old stock from Prodinks/Sudhaus) and ordered new bottles from OCP, flushed carts and refilled.
With the new inks the result was even worse, I abandoned the printer and took a MX995 with only 900p from my stock.
After replacing the carts with conservation fluid, I placed freshly flushed and refilled cartridges and the nozzle check was perfect.
I tried @The Hat's cartridge test pattern to check the ink flow, but the cyan had some stripes.
After placing the cyan cart into a IX6550 the test was OK, so the cartridge was OK.
(I installed the IX6550 to have a comparision but did not yet did further checks to see if the problem will build up there also).
I did a cleaning, but the cyan continued with stripes.
After a deep cleaning the cyan and magenta were blocked.
By bathing I could revive the magenta but the nozzle check of the cyan was too light.
New bathing revealed that nearly no cyan color was coming out of the head and pushing on a wet kitchen paper showed the cyan flow was limited and there is no cyan print on the paper.
Both the old and new ink is clear.
So it seems to me the ink is reacting inside the printhead into an unresolvable clog.
I bath now in distilled water with a drop of dishwashing fluid and 25% isopropanol.
All help appreciated.
