- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I applaud your testing spirit. Now we know what happens after 2000 hours in your specific situation. What I don't know is whether the amount of ink purged is due to something other than the 60-hour parameter?...the printer had been idle for more than 2000 hours, and that’s a darn sight more than 60 hours.
Is this 60-hour massive ink waste thing a Myth or is it real
As I recall, there are other times a printer will purge ink other than at 60 hours since last use. Some of these are much longer than 60 hours. Could it be the amount purged in your example was the amount dictated by a time frame longer than the 60-hour mark and is therefore a different amount? Could it be the Quality Maintenance and/or nozzle check caused a different than expected purge pattern?
Is it also possible that by unplugging your printer from the power source caused a different type of purge parameter?
The bottom line is you may have introduced variables that skewed your test.
To actually test your hypothesis then plug your printer back in, print something to start the 60 hour clock fresh, power off or keep on the printer, then wait 61-70 hours since the last print and try another print job. Measure printer potty effluent.
Documentation from Canon on purge patterns might provide sufficient a more complete "picture" of events. However, if the printer's firmware has ever been updated then all bets are off.
