Another CR-10 upgrade....
I reckon I have solved my current humidity problem using this contraption.
I placed two-reel holders in the bottom of a used clean plastic paint bucket, after I had drilled a small hole in the side of the bucket to accommodate a nut and bolt to allow the filament to feed while in the closed bucket.
reel-rollers-2-jpg.5904
The filament reel sits nicely on the reel holders, with the filament going out through the hole and I also placed a 500-gm bag of Silica pellets and a Hygrometer in the paint bucket to check the moisture contents for a couple of weeks.
All I got to do now is to refine my CURA print setting to get back too better-quality output, it’s amazing how much I’d forgotten...
Nice idea. I guess you already know that the silica gel can be regenerated by drying at 120C/250F for an hour in an ordinary baking oven?
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
I'm going to be doing something similar with an airtight plastic container like this: https://amzn.to/2wHF3U6
To build this: https://www.thingiverse.com/thing:2439008 or this https://www.thingiverse.com/thing:2779886 or this https://www.thingiverse.com/thing:2818547
Similar to the one in this video: https://www.youtube.com/watch?v=r8nNoDIp-Is
Probably using the teflon / bowden tubing holder here: https://www.thingiverse.com/thing:814597
... and maybe internal tube / roller holder held up with this: https://www.thingiverse.com/thing:2577759
That’s great @Nifty, but it looks a bit expensive.....:oops:
My problem was I never suffered from any issues regarding moisture with PLA before, ABS yes, because I was constantly using the filaments and never give the moisture a chance to build up in it, till my printer went down. :confused:
Now that I’m more aware of the moisture issues, I plan to make another container up for my second printer, once bitten twice shy, ignorance maybe contagious, but it can be cured, thankfully if I’m anything to go by... :eek:
FryingSaucer
Not if the main user of the oven says she doesn't want silica gel anywhere near her food:(
Administrator
Bay Area CA
I put my desiccant into my Modified Dehydrator For Drying Wet / Moist 3D Printer Filament and it works GREAT!
I ordered a few hygrometers to put into my dry-box I'm making, as well as any other bags / packs that I store my filament in. Hopefully this will help with some of the issues I've had (specifically around filament getting brittle).
