replied to the thread
How to generate a simple RGB printer profile using ArgyllCMS and the CR30 colorimeter/spectrophotometer
@ohtoulouz Here I have a 560 patch target for the CR30 that needs 2 sheets of A4 to be printed and should be more accurate.
Feb 14, 2026
K
knowing
Script for Printer Calibration on Windows, MacOS snd Linux (free to use and modify)
Hi All, I made an update, solely on the folder with Pre-made Targets. See Argyll_Printer_Profiler. I organized it a bit better, and...
Feb 14, 2026
K
knowing
Thanks for the tip. Anyone if free to help out with this. I am swamped with things and cannot really do that now. I have asked a couple...
Feb 14, 2026
K
knowing
reacted to
riclin's post
in the thread
with
Like
Perhaps slightly off-topic, but if ever you do feel inclined to port this to Windows, try passing the whole palava to Anthropic Claude...
Feb 14, 2026
riclin
Canon pro 10s streaks troubleshooting
Good spot Peter - I use Linux so can't use the Canon s/w - hence using web interface instead. So both are options. Now - did this...
Feb 13, 2026
reacted to
PK Project Manager's post
in the thread
with
Like
Huge congrats, @The Hat! Your photo just snagged Picture of the Week and is now featured on our homepage! 🎉📸
Feb 13, 2026
riclin
I think it's in the custom settings section of the web interface (which assumes of course that your Pro10S is networked, not just USB)
Feb 13, 2026
C
Cassiop38
No ! I wasn't aware such setting existed, i'll have a look. Thanks
Feb 13, 2026
riclin
Have you ticked the "Prevent Paper Abrasion" setting via the printer's web interface?
Feb 13, 2026
C
Cassiop38
Epson XP-8700 smears troubleshooting
might be, i bought it alongside a canon pro 10s and like you said it is not produced anymore. The paper seems okay but guess either it...
Feb 12, 2026
Artefil
Canon G6020 problem with a gear used for paper advance
Done, without help.
Feb 12, 2026
You may check the storage conditions - temperature and humidity - you are keeping your papers in. Photo papers with a carton type...
Feb 12, 2026
K
knowing
Yes, it can be hard to see changes in accuracy in the 3d plot, especially if the improved areas represent points inside the 3d volume...
Feb 12, 2026
riclin
Feb 12, 2026
C
Cassiop38
Since i solved the problem of my epson by switching paper, i'll do the same on the pro-10s once i switch to Canon's ink... Might be a...
Feb 12, 2026
