S
Soso
reacted to
garya's post
in the thread
Need help disassembling ink path on Epson 3880 (totally blocked LM channel)
with
Like
Thanks for the feedback. I have not yet taken the ink supply tubes off, although I did partially dismantle the printhead and try to...
Feb 11, 2026
X-File
reacted to
Smile's post
in the thread
Colormunki Photo device and ccStudio
with
Like
I also got a "old i1pro" "licensed for EVERYTHING" the biggest scam by X-rite is the re-certification/calibration if your instrument...
Feb 11, 2026
ohtoulouz
reacted to
pharmacist's post
in the thread
How to generate a simple RGB printer profile using ArgyllCMS and the CR30 colorimeter/spectrophotometer
with
Like
Did you tried a different rendering intent like perceptual intent with BPC enabled ? Normally 300 patches will already do a good job...
Feb 11, 2026
ohtoulouz
replied to the thread
No, I generally use Relative colorimetry with BPC. To be honnest, the result is quite good with your target. Maybe, I'll try to refine...
Feb 11, 2026
X-File
Calibrite Profiler 3.0
If anybody did the upgrade for the ColorMunki already: Is the device after the upgrade still working with older/original versions of the...
Feb 11, 2026
Feb 11, 2026
I
ice-t
Aldi glossy paper 21 Jan 2023 version
So, almost 3 years later i printed over 1000 photo's with this photopaper, at Amazon.be they raised the price from 9.95 to 11.99 E , at...
Feb 11, 2026
ohtoulouz
Hello @pharmacist I made the profile with your 300 patches target. There is a very slight improvement in the shadow, that are less red...
Feb 11, 2026
ohtoulouz
reacted to
pharmacist's post
in the thread
with
Like
I would start with my 300 patch target. I have tested the profiling making with 3 printers: dye printers like the Canon TS705 and the...
Feb 10, 2026
ohtoulouz
Thanks. I will try. I began with ~200 patches because I thought that 300 were too small. But, with a bit of practice, I think I can...
Feb 10, 2026
Feb 10, 2026
ohtoulouz
Well, I think I have another question. I have two printers: an Epson XP-970 and a Canon pro-300. I tested paper profiling on the XP-970...
Feb 10, 2026
ohtoulouz
reacted to
pharmacist's post
in the thread
with
Like
spectral band between 400-700 nm is almost the same as the much mor expensive i1Pro2: 380-730 nm. The reason why this small device does...
Feb 10, 2026
Feb 10, 2026
reacted to
ohtoulouz's post
in the thread
with
Like
Hello, I got a response from CHNSpec about various questions I had about the CR30. Here it is: "- The CR30 will display a red light...
Feb 10, 2026
