K
knowing
replied to the thread
Using ArgyllCMS + Colormunki to produce excellent printer profiles
Hi, Sorry for this duplicate post again. I made another significant modification and release of the script, as the menu system was very...
Feb 6, 2026
K
knowing
Script for Printer Calibration on Windows, MacOS snd Linux (free to use and modify)
Hi, I made another significant modification and release of the script, as the menu system was very rigid and with bugs. Now both...
Feb 6, 2026
A
adl7
Paper Jams in M607n- 13.B2- Just Replaced the Pick Up and Separation Roller Assemblies
Thank you!
Feb 6, 2026
A new beginning for my Lamp standard.. (Yes another One ! )
Looking great :clap:thumbsup
Feb 6, 2026
reacted to
The Hat's post
in the thread
with
Like
As for naming my bright new girl.. Well I’ve only got one good suggestion so far from @Redbrickman, and he came up with Bonnie, because...
Feb 6, 2026
K
knowing
You are right, but a bit more interactive configurability of defaults I like for Colormunki. It's not that big of an issue anyway. I...
Feb 5, 2026
K
knowing
I have now updated the script to support Linux. That was doable, but I doubt I can support Windows without rewriting the whole script or...
Feb 5, 2026
brian_mk
Epson 1500W print head replacement
I found a F173060 print head on eBay UK for just under £70. It was described as 'opened, never used'. When it arrived, the packaging was...
Feb 5, 2026
C
crenedecotret
I had a look at the script. It will ask you what device you are using and how many patches you want. It then holds your hand a little...
Feb 5, 2026
C
crenedecotret
i1Profiler miniature + small RGB printer targets: 10x15 cm, 13x18 cm, A5
These are the same settings I typically use but with a few changes - The table size I set to Maximum quality. I don't know if this...
Feb 5, 2026
K
knowing
Yes, sorry about that. I only have mac. Someone could modify it though.
Feb 5, 2026
My Windows computer says NOOO....cannot have a look at it, Apple only.
Feb 5, 2026
K
knowing
Yes, sorry about that. Changed my mind where to post.
Feb 5, 2026
Just to say my 572 patch target is also generated with the pkpatches tool like you did thus similar results as expected with the targen...
Feb 5, 2026
If you have license for i1Profiler: what you can do for more neutral profiles is in the profile settings (after you have scanned the...
Feb 5, 2026
