C
crenedecotret
replied to the thread
i1Profiler miniature + small RGB printer targets: 10x15 cm, 13x18 cm, A5
Thanks!! Below is the message that got me confused in i1profiler and then looking for other solutions. From your demo, it seems to...
Feb 4, 2026
L
Lothman
reacted to
pharmacist's post
in the thread
with
Like
reading a row: As you can see it works perfectly reading a few rows:
Feb 4, 2026
reacted to
Epatcola's post
in the thread
How to generate a simple RGB printer profile using ArgyllCMS and the CR30 colorimeter/spectrophotometer
with
Like
The ti3 generation script I wrote for the CR30 doesn't write an ink limit so it is a non-issue for that usage. Scanning the list you...
Feb 4, 2026
E
Epatcola
Feb 4, 2026
E
edmundronald
To get back to argyll, do you think that in light of the following, setting the ink limit of something like 310 might be preferable in...
Feb 4, 2026
E
Epatcola
The batch files have 2 lines. One to run targen and the second to run printarg. You don't need to be a programmer to edit command line...
Feb 3, 2026
ohtoulouz
Yes I downloaded your script too. They work fine with the test files. Thanks a lot. My last concern is the way to read the patches: the...
Feb 3, 2026
ohtoulouz
reacted to
Epatcola's post
in the thread
with
Like
Assuming you use windows you would be better off using the powershell script here and also check my post which details how to generate...
Feb 3, 2026
E
edmundronald
You will be welcome on the Argyllcms list, it's doubtless of interest to you! Here is where the bug descripton starts in this month's...
Feb 3, 2026
E
Epatcola
A bit more information on the bug would be interesting. We are not all using the same ones. The required patch size depends on if you...
Feb 3, 2026
E
edmundronald
- I think the latest Argyll has a bug and it may be better to regress a bit. - why can't someone post the target files directly if you...
Feb 3, 2026
E
Epatcola
Feb 3, 2026
Saving a canon pro 10 printer, one day at a time.
Anyway, it will make you sick when you see "how the printer waste it's ink", so don't do it. Use the printer for photos, posters...
Feb 3, 2026
C
Cassiop38
I just want to. It's both to keep the "waste tank" clean (canon should be hanged for handling waste ink like that !) and to monitor how...
Feb 3, 2026
reacted to
The Hat's post
in the thread
with
Like
If @Redbrickman can post his little red devil, then.. Here’s one of my new prints too.. the old one was looking a bit dated.. New...
Feb 3, 2026
