A
avolanche
reacted to
PeterBJ's post
in the thread
251 & 250 Toner Cartridges Question
with
Like
Canon OEM inks are the best but also most expensive. Used with OEM photo paper they are much more fading resistant than aftermarket...
Feb 2, 2026
C
Cassiop38
replied to the thread
Canon Pixma Pro-10 B200 Error
You can strap a pro-300 or 310 printhead into a pro-10 or pro-10s ? that's would be fairly amazing
Feb 2, 2026
Need help disassembling ink path on Epson 3880 (totally blocked LM channel)
Another problem can be air bubbles in ink tubes of printers with an ink supply system with tubes .
Feb 2, 2026
I'm not familiar with the ink supply of the P3880 in detail, but most cartridges, as well Dampers, have a spring loaded valve at the ink...
Feb 2, 2026
ohtoulouz
How to generate a simple RGB printer profile using ArgyllCMS and the CR30 colorimeter/spectrophotometer
Hello guys, Searching for printer calibration, I found this (very interesting) thread yesterday and I think that I have understood the...
Feb 2, 2026
ohtoulouz
posted the thread
Greetings from France
in
Canon InkJet Printers
Hi All ! Few words about me. I am french and decided last year that I should print my photos. I bought a Canon pro-300 which I am very...
Feb 2, 2026
T
thebestcpu
New printer suggestion requested
Here is a link to the online manual about the ability for the 3070 series (which includes the 3270) to print postcards...
Feb 1, 2026
B
bk13
hello thebestcpu, That looks pretty good. But, I don't know how to find out if it really prints postcard. Mine should do it. But...
Feb 1, 2026
G
garya
Thanks for the feedback. I have not yet taken the ink supply tubes off, although I did partially dismantle the printhead and try to...
Feb 1, 2026
I remember seeing a similar problem on a P400 printer -frequent and pretty persistent clogs. It turned out that the filter in the...
Feb 1, 2026
i1Profiler miniature + small RGB printer targets: 10x15 cm, 13x18 cm, A5
Here you are. I have used ArgyllCMS to generate the patches as it distributes the measurement points more evenly in the RGB 3D color...
Feb 1, 2026
Hi @crenedecotret, I can make you an i1Pro1 target for you for several pages of 4x6" photo cards.
Feb 1, 2026
T
thebestcpu
You might want to check this one out: https://www.usa.canon.com/shop/p/pixma-g3270?color=Black&type=New I don't know a lot about this...
Feb 1, 2026
B
bk13
Thanks for the reply. A bit out of my range. The majority of my printing is letters to politicians. Plain B&W. But sometimes I need...
Jan 31, 2026
W
W. Fisher
Maybe use some edit program and make the entire sheet of paper magenta with whatever RGB values that is? Maybe (R=255,G=0,B=255\)). It...
Jan 31, 2026
