replied to the thread
Hi there!
Hi Thilo, I am glad you managed to write your first post finally. Enjoy the forum like I have done in the last decades and hopefully we...
Jan 9, 2026
Printprism: I have bought it to test its capabilities and quality of the rgb profiles
There is already a new version 1.11 available, the software does not appear to be stable yet.
Jan 9, 2026
reacted to
Thilo's post
in the thread
Hi there!
with
Like
Hi there, I'm Thilo and new in this round. It's impressive to read an learn from your experience. I'm mostly exploring the many options...
Jan 9, 2026
OK Mike just give me the latest version and the problem is now solved. The previous version had a bug not able to find the file.
Jan 9, 2026
Thilo
posted the thread
Hi there!
in
Member Introductions
Jan 8, 2026
OK, I just installed the software and unfortunately it did not install the necessary printer-target-40.tif on my system (must be bug I...
Jan 8, 2026
E
Epatcola
Hopefully you can do what the author has failed to by posting a Printprism created profile for an ET-8550 supported Epson paper. One of...
Jan 8, 2026
E
Epatcola
reacted to
pharmacist's post
in the thread
with
Like
Today I bought a license of the Printprism to generate rgb printer profiles. I have the ET-8550 printer/scanner so I will give it a try...
Jan 8, 2026
posted the thread
in
Printing Photos and Photo Software
Jan 8, 2026
ThrillaMozilla
Colormunki Photo Jig + Yellow Cast?
Well, I was hoping for a software solution. The i1Studio software does not do this. It allows adding some color patches to a print...
Jan 7, 2026
A
AmaDeuSbg
posted the thread
Epson L1300/ET14000 cyan and black nozzle issue
in
Epson InkJet Printers
Hello, This community has proven really helpful and caring in the past and I hope that you can shed some light on that issue because it...
Jan 7, 2026
H
Hugorm
IP7250 paper problem
Mechanical out of sync? Could it be firmware related? Two (2) NG is version 1.101 - one (1) OK is version 1.090. Should I compare...
Jan 7, 2026
M
mavtop
How to use an unlicensed i1Pro spectro with i1Profiler and ArgyllCMS
Thanks a lot @pharmacist i hope to have some time to try them all
Jan 7, 2026
H
Hugorm
I've check the spring around the paper feed and found no differences between the three printers. On the sheet not being fed there are...
Jan 7, 2026
L
Lothman
reacted to
oliver666's post
in the thread
desktop lamp with high CRI for judging prints
with
Like
If you’re trying to avoid the "sell a kidney" prices of professional D50 booths, check out some of the dimmable LED floor lamps instead...
Jan 7, 2026
