M
mavtop
replied to the thread
How to use an unlicensed i1Pro spectro with i1Profiler and ArgyllCMS
the big window is 20cm large (why so short if i enlarged your project ?), so i suppose is this the problem. the sensor window is 21,2cm...
Dec 22, 2025
suwaidionlineuae
Epson 378 cartridges and resetter question
You can use a resetter for Epson 378 cartridges to make the printer recognize them as full again. Success depends on cartridge type...
Dec 22, 2025
The area is exactly 22.3 cm as my design takes into account the scanning eye will start en stop on white paper and in between the row...
Dec 22, 2025
T
thebestcpu
reacted to
ThrillaMozilla's post
in the thread
Colormunki Photo Jig + Yellow Cast?
with
Like
Dr. Nick wrote: Using the spotread command I noticed that argyll measures a LAB value of about -93 / 0 / -3 when the instrument is...
Dec 22, 2025
ThrillaMozilla
Dec 21, 2025
Tell me first the maximum distance you have between white and white area using the ruler and tell me the distance for example 24 cm, so...
Dec 21, 2025
C
Cassiop38
yes... i'm currently trusting a 13€ kit of 6 cartridge found on amazon and i'm afraid they leaks at some point. So far so good but you...
Dec 21, 2025
M
mavtop
@pharmacist today i tried to use your enlarged ruler (we used a value to increase the length) to scan using i1profiler v3.1.1 for Mac...
Dec 21, 2025
M
mavtop
if i remember good @pharmacist had troubles after 3/4 refill with the aliexpress cartridge, use the original, i already refilled them 5...
Dec 21, 2025
ilvals
Thank you so much for your reply! I've read your first message several times already. Did I understand correctly that the full command...
Dec 21, 2025
ilvals
reacted to
pharmacist's post
in the thread
with
Like
Standard printer profiles are using the D50 observer at 2 degrees (1931_2) thus: colprof -v -qh -i D50 -o 1931_2 -S AdobeRGB1998.icc...
Dec 21, 2025
Artefil
reacted to
websnail's post
in the thread
HP Firmware lottery - Again
with
Like
In case anyone has an HP printer that has received that joyous of all wonderful gifts, ie: a firmware update over July/August (2022)...
Dec 21, 2025
Dec 21, 2025
ilvals
Friends, please, I really need your help. For more than two months now I’ve been trying to create a profile for Epson L8050/L18050...
Dec 21, 2025
H
hdtvjeff
Canon Imageprograf TC 21 /Lucia TD inks and harvesting inks from 300ml/ 700 ml cartridges
I am looking to refill the CMYK Canon ImagePrograf TC 21 with CMYK ink which is also pigmented but not Lucia based with regular OEM...
Dec 20, 2025
