C
Cassiop38
replied to the thread
Epson 378 cartridges and resetter question
Really ? I had no luck resetting ARC chips on the 24XL i used for the XP-960 i had. If it's different for the 378 that's great ! I have...
Dec 19, 2025
If you have an EU version XP-15000 then the resetter will reset both original as well as aftermarket on-time reset and auto reset chips...
Dec 19, 2025
H
hdtvjeff
Canon Imageprograf TC 21 /Lucia TD inks and harvesting inks from 300ml/ 700 ml cartridges
Indeed. Just wish i knew for sure if the Canaon Imageprograg TC 21 used Lucia TD inks as AI says but Canon won't verify CMYK should be...
Dec 18, 2025
You have quite a range of inks you can use, but you would need to run some tests - profiles to verify all your assumptions.
Dec 18, 2025
C
Cassiop38
Good to know. I have a european printer which is fitted with almost empty original epson cartridges. i'll probably buy this kit anyway...
Dec 18, 2025
H
hdtvjeff
In newer ink set released at the time the TC21 was released we now have a newer Magenta color in Their TX TX and TM ink sets which are...
Dec 18, 2025
M
mavtop
the Epson 378 cartridge are Claria HD and the Epson 106 bottles are a good replacement like @Ink stained Fingers fade tests show Using...
Dec 18, 2025
C
Cassiop38
posted the thread
in
Epson InkJet Printers
Hello, i was wondering if you can reset original Epson 378 cartridges with a cheap resetter from aliexpress or if it only works on...
Dec 18, 2025
all colors of the GI-56 inks for the GX.... series printers are pigment inks...
Dec 18, 2025
C
Cassiop38
posted the thread
Oups ! i did it again. Canon Pro-1
in
Canon InkJet Printers
Got this 35kg paper weight for 50€ !! Bit of story first : I'm new here but long time lurker as i try to revive stuff for more than a...
Dec 18, 2025
H
hdtvjeff
Thank you, it seems the GX series uses a hybrid of Pigment and Dye based not all pigment like the TC 20/21 models
Dec 18, 2025
suwaidionlineuae
Brother DCP-J4110DW Print Profile
The thread you linked is from a user whose Brother DCP‑J4110DW prints photos with dull, slightly desaturated colours even after...
Dec 18, 2025
I don't see a reason why Canon would hide Lucia inks and not telling you the benifits of that ink: I tather would assume that the TC-21...
Dec 18, 2025
H
hdtvjeff
posted the thread
in
I really do not know and don't trust AI completely The brand new Canon ImagePrograf TC 21 is a CMYK 24 inch plotter. I would love to...
Dec 18, 2025
T
thebestcpu
DPP and PSP not seeing my new TR4775i printer.
I agree with @Tony4597 Yet your issue may not be a driver issue when the printer is not recognized. Here are some generic steps that...
Dec 17, 2025
