T
thebestcpu
replied to the thread
Colormunki Photo Jig + Yellow Cast?
Hi @oversetay2057 The targets need to be printed with absolutely no color management or color profile conversions, yet with printer...
Dec 16, 2025
A
Apple Mango
posted the thread
PRO-100 FW 2.031 - Reset Ink Absorber Help
in
Canon InkJet Printers
Hello, does anyone know how to reset the ink absorber on a PRO-100 FW 2.031? I was able to reset one on FW 1.something, but it did not...
Dec 15, 2025
Tony4597
reacted to
Nifty's post
in the thread
I CAN have nice things, right?!?! Pulling the trigger on a Bambu Lab H2S
with
Like
The H2S arrives this evening! I'm kinda nervous and excited.
Dec 15, 2025
ThrillaMozilla
It probably will affect readings. That's a big change in the relative distance from source and sensor to subject, and even a small...
Dec 15, 2025
reacted to
The Hat's post
in the thread
Prusa's answer to the Bambu and Creality models
with
Like
I got the new Creality Ender-V3 Plus because one of my CR-10’s had an issue, I hated it from the start because of all its bells and...
Dec 15, 2025
reacted to
ConradH's post
in the thread
What 3D printing project are you working on today?
with
Like
Yes, entirely from my warped brain. Simultaneously with learning to print, I'm also learning Freecad 1.0. It has its quirks, but I don't...
Dec 15, 2025
Dec 15, 2025
How to use an unlicensed i1Pro spectro with i1Profiler and ArgyllCMS
here you are. You will surprised how good this small target is: you can hardly tell the difference with the larger patch sets.
Dec 15, 2025
K
knowing
TI1, TI2, CSV and printtarg target files for SpyderPrint Targets
Hi @pharmacist and others interested, I have now verified the following: 1. When targen is used with argument -d2 and -c sRGB.icm...
Dec 15, 2025
M
mavtop
Hi again @pharmacist i would like to have also a target patches for a single 10x15cm sheet (i suppose it will be around 120/140 patches)...
Dec 15, 2025
suwaidionlineuae
Epson XP-15000: how to mix dye ink with clear ink base to obtain red and grey using CMYK
Mixing dye ink with a clear ink base is possible, but it must be done carefully to avoid printhead clogging and color inconsistency. For...
Dec 15, 2025
reacted to
superjudge's post
in the thread
with
Like
Oh, couple of other things, if you uncheck the box that says "only use presets" next to Paper Type, it'll show you the machine-level...
Dec 15, 2025
reacted to
superjudge's post
in the thread
with
Like
I turned the whole process into a PowerShell forms gui. There's a bat launcher that detects PS5 and PS7 (PowerShell Core), and launches...
Dec 15, 2025
T
thebestcpu
Turning off printer with a master switch
I personally don't like turning off the power at the power plug for electronic equipment. That is very similar to a power outage...
Dec 14, 2025
flyboy
posted the thread
in
Laser Printers -Everything-
Hi, I just got a MFC-L3765CDW. Works great, Too early for a report but I have a Epson ET 3750 and if I put it on a switched circuit...
Dec 14, 2025
