N
nitsuj1972
replied to the thread
Problems with no printing
Hi, Thanks for your help. I am confused as the Magneta catridge is full. Is there a fault with the catridfge?
Oct 5, 2025
J
josias
St4905 Canon Reset Tool
but how to download
Oct 5, 2025
There is also a bug in the gui.py (@x64, @micronica ): despite you can give an external icc name, the internal icc name (that is...
Oct 5, 2025
with te latest version of ArgyllCMS I get an errorthat the ink limit is set to 290% by standard using colprof after I have done the the...
Oct 5, 2025
T
thebestcpu
Printing won't print solid black on documents with mixed text and color graphics
Hi Don Please print a nozzle check pattern, scan it, and post it as another reply in this thread. The nozzle check test is the first...
Oct 5, 2025
T
thebestcpu
Hi @nitsuj1972 Your issue is not to hard to explain. Note that on your test image about half of the magenta is not runnning on all...
Oct 5, 2025
T
turnpaper
How many of us are still refilling ink cartridges?
Refilling is still alive, though not as popular as it once was. Many people still use refillable cartridges, especially with older Canon...
Oct 4, 2025
reacted to
Epatcola's post
in the thread
with
Like
And a few batch files named paper_sizexpatch_countxpatch_size to generate various targets on one or two sheets.
Oct 4, 2025
E
Epatcola
Oct 4, 2025
N
nitsuj1972
Thanks for your help. Most time printer is idle. I use refill type i.e. compatible. Our of black now due to a head cleaning. Yellow...
Oct 4, 2025
Please print a nozzle check and post it here; are you using Epson cartridges or do you do refill ? What is the usage rate for your...
Oct 4, 2025
N
nitsuj1972
posted the thread
in
Epson InkJet Printers
Hi, I am trying to work out why l get green faint lines in the printer. I have changed cartridges but still get faint lines. When l...
Oct 4, 2025
reacted to
Epatcola's post
in the thread
with
Like
Yesterday I created an A5 target with 384 randomized 8mm patches. I printed it on half an A4 sheet of Epson Premium Glossy paper on an...
Oct 4, 2025
E
Epatcola
Oct 4, 2025
E
Epatcola
I am using 8mm patches and the rule I designed so you only need to see a couple of patch 'joints' to align the rule. I have never had...
Oct 4, 2025
