replied to the thread
I use this setting: colprof -v -qh -i D50 -o 1931_2 -S AdobeRGB1998.icc -cmt -dpp -D%par1% -C%par2% %par3%
Sunday at 6:15 PM
x64
I get the same flattened pane when processing your i1Pro1 .ti3 with ArgyllCMS. If you get a nice profile with the i1Pro1 .ti3 you...
Sunday at 5:58 PM
actually not, that should not be the case. It should like a inflated pear.
Sunday at 5:50 PM
reacted to
x64's post
in the thread
with
Wow
I'm getting some results, can generate icc profiles from converted csv to ti3. Difference between i1Pro1 vs CR30 seems reasonable, but...
Sunday at 5:10 PM
x64
Sunday at 4:29 PM
x64
reacted to
pharmacist's post
in the thread
with
Like
Not sure this will work, because I think the sample_LOC is defined in the ti2 file, where you might extract from there. Sorry I am a...
Sunday at 1:50 PM
reacted to
x64's post
in the thread
with
Like
Great, that is the spectral data we need. But can you provide it as a csv like before, the xlsx makes reading more complicated and does...
Sunday at 1:15 PM
Sunday at 12:57 PM
x64
Sunday at 11:55 AM
P
pdan
Epson ET-8550 Bronzing?
That's just me thinking out aloud. As I said before, I'm not going to give Epson £700.00 for a printer that uses inferior inks.
Sunday at 10:30 AM
Ohhh, I see an error: the LAB values is BLA instead of LAB...here is the new file: PLEASE use this file (400-700 nm spectral range).
Sunday at 10:01 AM
So I managed to include the spectra data: LAB + spectral data from 360-780 nm and a version with LAB + spectral data from 400-700 mm, as...
Sunday at 9:12 AM
Hi @x64 : Is will try to rescan the target again and include the spectral data from 360 to 780 nm in steps of 10 nm and also the...
Sunday at 8:46 AM
x64
Could you share another scan csv but with spectral data so I can include that for you. Because the CR30 is not included as target...
Sunday at 3:09 AM
Here is the device specs: https://en.chnspec.com/Product/info.aspx?itemid=441&lcid=246&id=228 software is called colorexpert
Saturday at 5:57 PM
