L
Loomray
replied to the thread
Epson ET-8550 Bronzing?
No ,your finger must be dry ,better you use a clean dry cloth. With damp finger the dye ink will also smudge/desolve.
Sep 11, 2025
just put a drop of water on the nozzle print and let it penetrate by itself and see if you see a black ring after the water droplet has...
Sep 11, 2025
P
pdan
What do you think? looks slightly smudged to me.
Sep 11, 2025
P
pdan
Smudge made with finger slightly damp:
Sep 11, 2025
E
Epatcola
Calibrite Profiler 3.0
I'm sure the posts here will contribute in a small way to information AI bots trawl from the internet and regurgitate so eloquently...
Sep 11, 2025
reacted to
Epatcola's post
in the thread
with
Haha
The most likely money grab is tying the hardware device to particular computers (which requires an internet connection to orchestrate)...
Sep 11, 2025
P
pdan
Great! thanks for the suggestion!
Sep 11, 2025
In that case did you buy from a legit reseller ? Epson's quality control is very good and the chances the PK or MK has be swapped is...
Sep 11, 2025
E
Epatcola
Sep 11, 2025
L
Loomray
That´s a havy operation on your printer.I have an easy test how to proof if your PB chanel(ink) is conterminated(however you mix it ,the...
Sep 11, 2025
Adobe already adopted this policy (although I am not very impressed by their AI generations - the stock lost 30% over a year). The...
Sep 11, 2025
P
pdan
Yes, you are indeed correct, it is a fail-safe smart solution...but only if the MK black and PB black ink have been correctly labeled in...
Sep 11, 2025
I find it particular with the fail-safe bottles it should not be possible to put MK into the PK container; it won't fit. The bottles...
Sep 11, 2025
Maybe a bit paranoia, but I think the next step will be some kind of pricing based on the profiles you make; most probably free for...
Sep 11, 2025
P
pdan
Thank you all for your suggestions. I'm making prints via Epson Print Layout, so no airprint issues. Since I had no issue with bronzing...
Sep 11, 2025
