P
pdan
replied to the thread
Epson ET-8550 Bronzing?
Great! thanks for the suggestion!
Sep 11, 2025
In that case did you buy from a legit reseller ? Epson's quality control is very good and the chances the PK or MK has be swapped is...
Sep 11, 2025
E
Epatcola
Calibrite Profiler 3.0
The most likely money grab is tying the hardware device to particular computers (which requires an internet connection to orchestrate)...
Sep 11, 2025
L
Loomray
That´s a havy operation on your printer.I have an easy test how to proof if your PB chanel(ink) is conterminated(however you mix it ,the...
Sep 11, 2025
Adobe already adopted this policy (although I am not very impressed by their AI generations - the stock lost 30% over a year). The...
Sep 11, 2025
P
pdan
Yes, you are indeed correct, it is a fail-safe smart solution...but only if the MK black and PB black ink have been correctly labeled in...
Sep 11, 2025
I find it particular with the fail-safe bottles it should not be possible to put MK into the PK container; it won't fit. The bottles...
Sep 11, 2025
Maybe a bit paranoia, but I think the next step will be some kind of pricing based on the profiles you make; most probably free for...
Sep 11, 2025
P
pdan
Thank you all for your suggestions. I'm making prints via Epson Print Layout, so no airprint issues. Since I had no issue with bronzing...
Sep 11, 2025
reacted to
Loomray's post
in the thread
with
Like
Me too,I am also a Windows user.And i set my Print density slider on -4 for the sihl paper. With my test i only will show that my ET8550...
Sep 11, 2025
This is another discussion, personally I am not so paranoiac . I would only mention that: a) the last Colormunki software from X-Rite...
Sep 11, 2025
L
Loomray
Sep 11, 2025
L
Loomray
reacted to
Ink stained Fingers's post
in the thread
with
Like
I don't think that I can be of further help, I work with Windows , and I'm doing a reduction of 10% when printing on the Sihl 280g ; I...
Sep 11, 2025
E
Epatcola
I'm not sure what you mean in the last paragraph. OS Updates might break screen calibration with older software. I'm sure I will still...
Sep 11, 2025
reacted to
in the thread
with
Like
Sep 11, 2025
