  • L
    Loomray replied to the thread Epson ET-8550 Bronzing?.
    That´s a havy operation on your printer.I have an easy test how to proof if your PB chanel(ink) is conterminated(however you mix it ,the...
  • palombian
    palombian replied to the thread Calibrite Profiler 3.0.
    Adobe already adopted this policy (although I am not very impressed by their AI generations - the stock lost 30% over a year). The...
  • P
    pdan replied to the thread Epson ET-8550 Bronzing?.
    Yes, you are indeed correct, it is a fail-safe smart solution...but only if the MK black and PB black ink have been correctly labeled in...
  • pharmacist
    pharmacist replied to the thread Epson ET-8550 Bronzing?.
    I find it particular with the fail-safe bottles it should not be possible to put MK into the PK container; it won't fit. The bottles...
  • pharmacist
    pharmacist replied to the thread Calibrite Profiler 3.0.
    Maybe a bit paranoia, but I think the next step will be some kind of pricing based on the profiles you make; most probably free for...
  • P
    Thank you all for your suggestions. I'm making prints via Epson Print Layout, so no airprint issues. Since I had no issue with bronzing...
  • pharmacist
    pharmacist reacted to Loomray's post in the thread Epson ET-8550 Bronzing? with Like Like.
    Me too,I am also a Windows user.And i set my Print density slider on -4 for the sihl paper. With my test i only will show that my ET8550...
  • palombian
    This is another discussion, personally I am not so paranoiac . I would only mention that: a) the last Colormunki software from X-Rite...
  • L
  • L
    Loomray reacted to Ink stained Fingers's post in the thread Epson ET-8550 Bronzing? with Like Like.
    I don't think that I can be of further help, I work with Windows , and I'm doing a reduction of 10% when printing on the Sihl 280g ; I...
  • E
    Epatcola replied to the thread Calibrite Profiler 3.0.
    I'm not sure what you mean in the last paragraph. OS Updates might break screen calibration with older software. I'm sure I will still...
  • pharmacist
    pharmacist reacted to Ink stained Fingers's post in the thread Epson ET-8550 Bronzing? with Like Like.
  • Ink stained Fingers
    Ink stained Fingers reacted to pharmacist's post in the thread Epson ET-8550 Bronzing? with Like Like.
    Let me guess: MacOS ????... DON'T install the Airprint driver, that is a recipe for disaster. deinstall them and install the ones of...
    Are you sure ??? MacOS tends to override the drivers after an update overwriting the previous proprietary Canon and Epson drivers with...
