K
kawliox
replied to the thread
small lines/streaks when printing photos
you have a good eye my friend. It really seems as magenta is the problem here. See the pic where lines in magenta and black are more...
Mar 25, 2025
Y
yonubear
ipf605 timing strip help
thats what i thought but if i use the 2 hooks that I assume are where it was then it is super slacked and I can't seem to get it to stay...
Mar 25, 2025
x64
Usually those are in place with some hooks you will find parallel to the guide rails, with a spring on one side to keep it under tension.
Mar 25, 2025
Converting Spyderprint 225 patch target to i1Profiler
I just produced a target using the above combined high quality target + grays (from the Spyderprint target) and used i1profiler to...
Mar 25, 2025
alexisD
Canon TS5150 - Dark Stripes When Printing Images
Hey everyone, thanks so much for all the responses! 🙏 I spent quite a bit of time tinkering yesterday — tried out tons of settings and...
Mar 25, 2025
alexisD
reacted to
thebestcpu's post
in the thread
with
Like
Hi @alexisD I am not 100% sure of what i think the problem is yet several factors fit. Here is my understanding of the issue. You are...
Mar 25, 2025
Am I defecting to Canon ?
Both the T2100/3100X and the TC-20 are entry level 24" printers as described in detail. one of the limitations (intended by Canon or...
Mar 25, 2025
A
andy1978
I am currently facing a significant dilemma regarding the choice between the Epson SureColor T2100 and Canon TC-20 printers. My primary...
Mar 25, 2025
T
thebestcpu
Mar 25, 2025
T
thebestcpu
Hi @kawliox I think you should give the light magenta nozzle check another look and compare to the other colors I stitched you two...
Mar 24, 2025
Y
yonubear
posted the thread
in
Canon InkJet Printers
hi, I am hoping that you all can help me out I just picked up a secondhand imagePROGRAF ipf605 and the dang carriage timing strip came...
Mar 24, 2025
D
Dr_Nick
That's actually something I did a while ago. You can use Spyder Print with argyll but it requires some messing around with files. You...
Mar 24, 2025
ET-7750 Ink pool at hub causing ink smearing?
i must admit that I'm not really clear what you have done or are trying to do. The main problem with the ET-7750 was the build-up of ink...
Mar 24, 2025
K
kawliox
HI, here are the pics of nozzle check, for me looks totally fine, I did also both vertical and horizontal alignment, I use Epson 3 star...
Mar 24, 2025
T
thebestcpu
Hi @kawliox Are those actually ink stripes or scapes caused by rubbing up against the printer print head? Here is an image of part of...
Mar 24, 2025
