InkQuisitive
- Apr 1, 2013
Hi all
I just did my 2nd ever refill: a set of 525 / 526 cartridges via top fill. All seemed to go well: shaved an hour off of last week's attempt and not a drop of ink was spilled
. Just a bit of minor bubbling out of the fill hole on a couple of them where I didn't keep a close enough eye on the scales
After filling last time and this I balanced the cartridges over a bit of paper for ~20 mins to help check for leaks. While they rest there I dab off the drop of ink that slowly appears on some of them, so that once this stops building (presumably the sponge and everything have settled down) I can clip them for storage and they will hopefully be drip free when the clip is removed for installation in the printer.
But on the 526 black I found that after initial filling the outlet port was 'dry'. Touching it with kitchen paper resulted in still-clean paper
. Eventually (maybe due to pressing a pad of kitchen paper against it to try and draw the ink) it started to work 'as normal' - touching it rapidly wicked ink onto the paper.
My question is whether it is likely to work OK when finally installed, or should I expect some issues from specks of dried out ink that might be in the port? I tried finding others previous experiences on this, but suspect I'm missing the magic search phrase
BTW, no idea why it dried out when others hadn't. It was actually the fullest of the ones I was refilling so I'd have expected that to keep it wetted. I guess that when a couple of the colours had run out from the set of tanks that were supplied with the printer I must have replaced the full set (or at least any showing a low-ish level) and the black came out even though it may not have needed to. The removed ones then had Canon twist-off caps taped back in place, which seemed to have kept the others damp :/.
