I just put new cartridges in my canon mp980 . The yellow and black had gone dry for about a month, I know that is bad, so I removed the print head and cleaned it with alcohol and distilled water. I flushed the screens where the cartridges connect in the holder. I put a paper towel under the print head and used a syringe to draw ink from a refill bottle and slowly injected some of it into the screen for each color until that color came out on the paper towel. The yellow was really problematic. I had to use a syringe with alcohol to clear it out then flush it again with yellow ink. finally all colors were working. I also cleaned both the purge pads and the tray below as well as the tubing.
Installed and printed a test page, it was bad so I did deep cleaning until it printed fine. Then I did print head alignment and that finished ok. Next I wanted to test a photo print and that is where the problems started. I was just wanting to test the colors so it was set to fast printing and low quality. Below is what it is printing anytime I try to print an image. I have never seen anything like that. Any ideas on how to fix it or what the problem may be ?
From the printer
Original in photoshop
From the printer
