I have PIXMA MX700 for over a year now. The last couple of days it has stripes on color printout, but full B/W text (and faxes) printed ok.
I have done head cleaning, deep head cleaning, manual head cleaning, no improvement.
The nozzle check pattern is as below:
White horizontal stripes of about 3mm alternating with printed images (also about 3 mm).
The white stripes are well defined and tidy (not degrading like inks running out gradually).
This printer is attached to home network, and I have printed from multiple PC and laptops with similar result.
All cartridges have adequate amount of ink in reserve. All CANON original (because i don't use the printer so much, so the the difference between buying original and aftermarket inks for my purpose is negligible).
I have tried various methods of nozzle cleaning, deep nozzle cleaning both from printer maintenance menu and manual print head cleaning. No improvement whatsoever.
I don't like the idea of buying new printhead only to found out the the problem is actually in the printer main circuitry, and I ended up with a perfectly functional spare, and a broken printer which will likely be tossed out anyway (service support in my area is virtually nonexistent).
Any help will be appreciated.
Thanks.
inoe
Thanks.
inoe
