Wallet photo edit software
MikeY69
Los Angeles, California
I am looking for a software that can create adjustable size wallet photos (sometimes I need to print 8 of 2 1/2x3 1/2 photos on 8 1/2x11, sometimes I need to print 8 of 2 5/8 x 3 5/8 photos on such sheet). Please help me locate it. Thanks.
drc023
Arkansas
Canon Pro-100, iP8720, MG6220
With any desktop publishing application (MS Publisher, PagePlus, Quark, etc...) you can import and resize or crop at will. Since they are page layout applications you can position the photos anywhere on the sheet. It isn't difficult to do, but it is somewhat tedious. Qimage might also be the answer, but I haven't used the application so I only guessing. You can get a free demo version by downloading it from www.ddisoftware.com.
MikeY69
Current I am using photoshop to do photo editing, however, it can print 8 of 2 1/2x3 1/2 in order, but, if I want to print 8 of 2 5/8x3 5/8, it only print part of them....
Grandad35
North of Boston, USA
Canon i9900 (plus 5 spares)
Mike,
(8) 2 1/2x3 1/2 prints as 10x7 and (8) 2 5/8x3 5/8 prints as 10.5x7.25. What is the maximum size that can be printed on the paper that you are using? If it is less than 10.5" the printer will crop the excess area.
Even if this is your problem, you might be able to select "borderless" in your printer driver to enlarge the printable area. You will probably also want to select a minimuim value for the "Amount of Extension" (or whatever your driver calls it) so that your images are kept completely on the paper.
