1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: Health & Safety and 3D Printing.
    CLICK HERE!
    Dismiss Notice
VP485 Label Printer - Ink Refills
Discussion in 'Everything Else InkJet Printer Related' started by Cargill, May 1, 2010.
  1. Nov 29, 2011
    Cargill
    Cargill Getting Fingers Dirty
    May 1, 2010
    10
    22
    When you say "refilling inks" - do you mean attempting to refill the original VP485 cartridges, or a CISS system? I have heard people can successfully have original carts refilled (either by themselves, or via a cartridge shop) and they will basically work forever - so long as you make sure they do not run out - that will wreck your printheads. But the VP485 is quite temperamental, I'm finding.
  2. Aug 20, 2012
    sgillesp
    sgillesp Printing Apprentice
    Aug 20, 2012
    11
    I was going through over $1500 in ink and eventually contacted the Australian company and bought their CISS for about $400. It came with a software trick to fool the pc. This option worked great. but the ink reservoirs were a little small. So I purchased a CISS from CISinks (I think any of the ones for the HP 88 will work, they list 4 or five different units). I installed this unit on a second vp485 I have and it has been in operation for about a year (no software trick needed as discussed from a previous review). I now spend less than $100 per month in ink and we run a ton of very big labels.
  3. Aug 20, 2012
    Cargill
    May 1, 2010
    10
    22
    Hi sgillesp - can you provide the name of the Australian company where you purchased the CISS with the small reservoirs? Glad to hear you're having a good result, including from CISinks. Some VP485 users here in Australia are buying the ink carts directly from the US for less than half the Australian cost, but original ink is still very expensive per litre that way.
    Glad to hear the printer is churning out labels more economically now.
  4. Oct 19, 2012
    punkmedics
    punkmedics Newbie to Printing
    Mar 21, 2012
    sgillesp I just got a vp485 did you need to swap chips on the CISS from CISinks or just use it as is?
  5. Aug 4, 2013
    Tpellizzer
    Tpellizzer Newbie to Printing
    Aug 4, 2013
    Cargill and sgillesp:are you still successfully using the ciss systems with the vp485? Which model from cuisines did you purchase? I see they have many to chose from. How did you handle the chip issue? The ciss system from cisinks is much cheaper than the unit from Australia. Des it work as well? I will be buying either a vp485 or primera lx900? Any ideas?
  6. Aug 4, 2013
    Tpellizzer
    Aug 4, 2013
    Forgot to ask:is the bulk ink the same quality as Oem?
  7. Aug 4, 2013
    Tpellizzer
    Aug 4, 2013
    Is it in the same color range?
  8. Nov 5, 2013
    Bertony
    Bertony Print Lurker
    Nov 5, 2013
    Printer Model:
    VP485
    I GOT IT TO WORK!!
    I have been struggling with this also, just trying to save some money on the ink cartridges, Vip is a little greedy with their profit margin, as well as I. So, today I bought an hp88 cartridge, obviously it doesn't work because of the chip, but after messing around with it for a bit. I realized the cartridge is in 2 pieces.......if you take the VIP cartridge and cut with a knife along the parting lines (near the bottom of the cartridge) where the label is you can snap the bottom half off (it doesn't have to break, the pieces just snap into each other) and just put it right back onto the hp88 cartridge, the chip and all. Works perfectly, and still 1/2 the cost. The chip is not related to colors from what I can tell, so keep the old cartridges, they will come on handy for this.
    The Hat likes this.
  9. Nov 5, 2013
    Cargill
    May 1, 2010
    10
    22
    Well done ... not as cheap as using a CISS, but certainly cheaper than using original VIP cartridges. Also you should be able to refill the HP cartridges, so long as you do so before the cart is empty - so the VIP chip in it doesn't register as empty. I think that's how it works.
    The Hat likes this.
  10. Dec 7, 2014
    kim emanuel
    kim emanuel Print Lurker
    Dec 7, 2014
    Printer Model:
    VP485
    I have had the VP485 for a little more than a year and 1/2 and not both print heads need replacement ... any thoughts if this is normal time to replace?
    Thanks
    Kim
Share This Page
