- Thread starter
- #741
itsab1989
- Feb 11, 2026
- Epson ET 8550, Canon Pro 300
It is hard to say what exactly went wrong. Some screenshots, the log files and / or the project folder might help to look into this.
Please take the following with a grain of salt because I am not 100% sure on this.
In the Check&Refine tab ChromIQ uses Argylls profcheck to get the data. This checks how well the values you have measured fit within the profile you have created. It is expected that the paper can’t exactly reproduce what you see on the screen but when the profile is created it takes into account your measurement but also does some smoothing and many calculations to correctly weigh all of this data.
If some patches you measured are then really far off that can shift a big part of the profile. And then check and refine tells you that this did not come out as expected. So chances are that when you re-measure the patches with the highes deviation and get them right the next time the whole profile falls more in line with the other measurements you have made. However you can’t say this for sure.
The judgement about the quality comes more or less only from how many patches fall out of the threshold you set in the tool.
And my thought was that when it flags so many patches that you uave to remeasure more then 50% of the chart it might be better to tell the user to start from scratch instead of reading single strips again.
Maybe this recommendation is not the best though.
Regarding how easy a measurement should be this depends a little bit on your skill as well. Of course making margins and patches bigger will make things easier and more forgiving (at least it should). But it helps a lot to move the device slowly, smoothly, always with the same pressure etc.
This sounds easy but I found it takes some practice. And on the flip side if I move my Colormunki too slow I get misreadings as well. Then it has a tendency to put your measurements to the wrong patches. It happened to me that they are off by one position a few times. The measured vs expected overlay and the red outlines helped me to spot those issues.
Truth is I can’t tell you whether this is an issue of only the ChromIQ chartreading engine or Argylls chartread as well. Because chartread is a black box and you can’t visualize its measurement the same way. But since we base our engine on the exact same code I suspect that it is actually the same for both and our engine only makes those errors easier to spot and correct.
