- Thread starter
- #301
itsab1989
- Feb 11, 2026
- Epson ET 8550, Canon Pro 300
@pharmacist
What kind of options would you need to create better chart layouts?
The arrangement of the options is not yet optimal I think. The placholder token need some work to show better instrument names I think. Everything has to be proved working. Some thing might need to be added. Some maybe are too much. But maybe it is a good starting point. This completely replaces printtarg (although it is based on its code). So I don't have to edit the tiff files after they are created but give them the desired layout at creation time. Also this makes it easier to calculate the amount of patches fitting a single page with the chosen settings. For original printtarg I had to run printtarg for various combinations of instruments, paper sizes and additional options and create a database out of those. If you chose a combination of options that had not been covered by this that process was done at creation time - it ran targen plus printtarg around 10 times in a row until it found a match. Should be faster here.
BUT: Very beta...
https://github.com/itsab1989/ChromIQ/releases/tag/v3.13.0-beta.4
BUT: Very beta...
