Tips of refilling for EPSON inkjet printer cartridge
shuwang
EPSON inkjet printer uses the Micro Piezo print head technology, through voltage changes crystal vibration to catapult the ink,which is characterized by high resolution can be easily achieved, with its unique ink technology, can be obtained perfect photo prints.
Despite its excellent print quality, but also more expensive cartridges! A lot of people want can be a the Refilling way to reduce printing costs,but not many people really do. Most users are afraid to improper operation may cause the printer to malfunction, or do not know how to operate.In fact, EPSON inkjet printer cartridges refilling compared to other machines must be convenient, as it is with the nozzle separation,therefore do not have to punch holes in just a few disposable syringes can complete the task.
Injected black ink steps are as follows:
1. Remove the cartridges: remove the black ink cartridge when the printer's black ink net indicator light, with the disposable syringes lessons 7ml ~ 8ml ink under the cartridge ink hole up and tilted 45 degrees to prevent refilling almost full ink liquid from flowing out of the balance hole of the upper portion of the ink cartridge;
2. Inject ink: ink disposable syringes slowly inject ink hole before refilling action to slow down after, repeat the operation several times, until it is completed. Observed through the left side of the transparent plastic cartridges of the ink filled cartridge capacity is 4/5 can be, not too full, and then wiping with absorbent paper to make the ink of the ink near the hole;
3. Into the printer: the cartridge is inserted into the bracket, the back must be close to the bracket, when the loaded positive position, the ink cartridge locking lever to push gently into place. Feel heavy, cartridges malposition, can release the locking lever, and the side of the cartridge to move up and down with his left hand, while with his right hand to gently push the locking lever, you can feel in place;
4. Clean the print head: open "My computer / printer / properties / control" to enter the "Cleaning the print head" After washing twice, and then print a test page, you can use.
If you want to add color ink, but slightly cumbersome, the basic steps are similar:
1. Remove the ink cartridges: Remove the color cartridge when color ink printer net light, to draw the different colors Aquarene 5ml around three disposable syringes, under the cartridge out of ink hole up and tilted 45 degrees to prevent refilling almost full when the ink flows from the balance hole of the upper portion of the ink cartridge;
2. Injection Aquarene: were slowly injected the different colors Aquarene disposable syringes respective ink feed hole, refilling to be little by little added to prevent the air pressure is too large so that the ink from beneath the ink hole ejection operation is repeated several times, Meanwhile, observation through the transparent plastic material of the side of the cartridge, color ink filled cartridge capacity of 2/3 can not be too full, and then with absorbent paper wipe to make out the ink of the ink near the hole
pearlhouse
Brunswick, Ohio USA
Canon mx892 & mx922
Im sure you spent some time on this but your conversion to english is very hard to understand. Im guessing thats why are not getting any replies.:)
finkey
Thank you Shuwang.
Here's a stripped down version on how to refill an Epson Workforce WF 2530:
Press Copy button on console.
Press Menu button.
Press down arrow on console to scroll to Maintenance.
Press OK.
Press down arrow to scroll to Ink Cartridge Replacement.
Press OK.
Printer will say Replace Cartridge.
Cartridge carriage will position itself outside its bay.
Lift out original Epson cartridge if this is the first time putting in a new, refillable cartridge.
Otherwise you can refill the refillable cartridge without taking it out of the carriage.
Shake briskly the capped bottle of ink.
Fill syringe with color needed.
Poke syringe needle right into fill hole, or through rubber color plug on refillable cartridge.
(Depends on what brand you bought where the fill up hole is.)
It's a straight forward thing, tilting the cartridge is optional.
Fill cartridge to the top. It takes about 3 syringes or 15 ml ink.
When done, press filled cartridge firmly back into carriage, if first time.
Press OK on the console.
Printer will check say Checking...
Ink not recognized, proceed? Choose Yes or 1.
Printer will again say, Replace Cartridge. Ignore that.
Turn off printer. (Don't press stop/reset button, it doesn't help.)
Wait 15 seconds.
Turn on the printer again.
The first time a new refillable cartridge is put in, and the printer is restarted,
the printer takes a long time to settle down. It may hover silently and click a bit.
Don't worry. It will settle into copy mode after about two minutes.
Next time, it will behave as normal.
Print a test page. Test pages always take a long time for the printer
to think about. Just wait, it will print out. If the print looks faded or
blotchy, do a head cleaning and try again.
The next page should be okay.
Check the fill status, you should see your new cartridge as full to the brim.
