Apr 8, 2016 #1 mikling Printer VIP Platinum Printer Member Joined Jul 2, 2006 Messages 3,239 Reaction score 1,472 Points 313 Location Toronto, Canada I got a call from a customer refilling and using his Pro-100 commercially. After 30,000 pages his black is getting streaky! What has gone wrong? He's also only using one set of cartridges. None of the cartridges have ever been flushed.
Apr 9, 2016 #2 turbguy Printer Master Platinum Printer Member Joined Sep 10, 2007 Messages 1,562 Reaction score 1,442 Points 293 Location Laramie, Wyoming Printer Model Canon i960, Canon i9900 Sounds like an ink flow issue. Try an OEM cart. Run a service test print. If OK, then just use the new cart for refilling...
Apr 9, 2016 #3 PeterBJ Printer VIP Platinum Printer Member Joined Nov 27, 2010 Messages 5,140 Reaction score 5,024 Points 373 Location Copenhagen Denmark Printer Model Canon MP990 Even if it is a bit expensive, I think a new OEM cartridge is the best test tool in this situation. Last edited: Apr 9, 2016
Apr 9, 2016 #4 The Hat Printer VIP Platinum Printer Member Joined Jan 18, 2010 Messages 15,916 Reaction score 8,923 Points 453 Location Residing in Wicklow Ireland Printer Model Canon/3D, CR-10, CR-10S, KP-3 This guy reckons the OEM cartridges should last forever, so did you tell him politely to go flush the darn things..
Apr 9, 2016 #5 Ink stained Fingers Printer VIP Platinum Printer Member Joined Dec 27, 2014 Messages 6,198 Reaction score 7,385 Points 373 Location Germany Printer Model L805, WF2010, ET8550, T3100X Or could it be a problem with the printhead instead, and not with the cartridge ? Switching to a new cartridge should directly show it.
May 6, 2016 #6 Grazer5 Fan of Printing Joined Sep 22, 2014 Messages 63 Reaction score 29 Points 58 Location Winnipeg, Canada Printer Model Pro-100, Ricoh Pro 7100S Definitely needs to be flushed. The bubbles must be horrendous!
