- Apr 19, 2007
- USA
- Canon MB5120, Pencil
Forum consensus is hard earned anecdotal evidence that is as close to the scientific method as we are going to get. While there will always be alternative methods of resolving issues - and YMMV - the forum consensus is a methodological progression in its approach to resolving issues that have produced success and have been repeatable. This, and that they are relatively non-destructive, are reason why the methods have become consensus and are recommended as baseline approaches to problem solving.I only can say that I also had issues who could not be explained or solved by the forum consensus.
I reviewed your thread on your problem. Some of this applies to the OP of this thread and is why I am I am posting here instead on your thread. While I noted you did try flushing cartridge(s), I don't see you tried a NEW cartridge. It may be the sponge(s) have separated or there is a "Gello" type effect of ink in the sponge. If your issue continued despite a NEW cartridge then you can be certain the cartridge is not involved. I do not see you tried this.
The FUNNEL shaped ink defect is fairly pathognomonic for ink starvation due to poor flow of ink in the sponge. It is unlikely an electrical malfunction would cause a cascade of loss of ink from the center to the outside of the ink loss area, especially if the ink loss can resolve and return as it has for you. Instead, an electrical malfunction will typically be an all or nothing event and typically be a straight line event. However, poor ink flow within the sponge would cause a loss of ink in the center of the sponge first where ink must travel further to saturate, and then the poor ink flow will gradually affect further out from the center. I also do not think a flow issue inside the print head would cause this funnel shaped defect that rapidly blooms to involve nearly the entire Cyan channel in your nozzle check unless some chunk of clotted ink was the cause, and then I would have to wonder how there is relatively constant and uniform ink deposited in the periphery.
At this point, because ink flow DOES return for a brief time in your nozzle checks, I continue to recommend you try a NEW cartridge, preferably OEM, and if that does not work then soak the print head using the instructions I linked in your thread and try again with the NEW cartridge. If you think this an effect of "Gello" then soak the print head for a few days first in Windex with Ammonium D to help dissolve the Gello, flush with water and consider a second soaking in liquid dish was soap like Dawn or Fairy for a few days.
