Paul Verizzo
- Apr 16, 2011
- Location
- Sarasota, FL, USA
- Canon ip4500, 9000 MK II, PRO-
OK, here are my iconoclastic thoughts about profiling. I'll probably put this up on a more permanent link.
PHILOSOPHY:
The poor man's ICC'ish color profiling.
I'm a graduate of the K.I.S. school of life's endeavors with a minor in Good Enough. In other words, how much time and effort and money is spent to tweak the last bits of whatever to perfection? (And then all that stuff like lighting variations, pigment ink problems, and human subjectivity undoes a bunch of that perfection stuff anyway.) Understanding the concept of diminishing returns, that with every additional input of time and money, the improvements are smaller and smaller. And that “stuff” is a poor substitute for skill.
Over the years I've collected quite a few step tablets, both physical and digital, or I scanned the physical ones. Besides any monitor adjustment you can do manually (and I have to say my Dell auto-adjust is pretty amazing,) a digital 21 step B&W tablet will instantly show if the highlights or shadows are being blocked. A well adjusted monitor will show a difference between each and every step. Got equality?
STARTING WITH MONOCHROME DENSITIES:
But you first need to make sure that the tablet is being seen as 0 in the black-most bit and 255 in the whitest. To do this, you need a photo/graphics program that will give the sRGB densities when you hover the cursor at a point on the step tablet. Canon Digital Photo Professional will do this, as will others. I presume Adobe products will, but I missed the Adobe gene, forgive me.
If you don't get 0 in the blackest rectangle and 255 in the whitest, you need to adjust the image by using black point and white point pickers in an appropriate program, and then save the image. The Kodak Color Portrait test print also has a handy 18% gray midpoint in a circle off of the woman’s face (and “perfect” Caucasian skin tone in another.) Use that portion for the "gray picker." You can download this image, with a monochrome B&W identical half that I combined at It includes a full range 0-255 adjusted 21 step tablet.
When you print that step tablet with your target paper and ink, you should see similar results, ideally. If not, you need different paper, ink, and/or profile changes. Canon printers, and I presume all others, let you make some manual adjustments which you can then save as a profile. Talking just B&W here, if either end of the spectrum is blocked, try reducing the contrast. Granted, this isn't an ideal Levels type curve, but it might work. Generally, I’ve found that if you have the full density range in the jpeg image, LCD monitors will show the gradations. Monitors are the least important in the lot of devices and programs used to make images.
ON TO COLOR:
This technique relies on the fact that scanners are usually equal opportunity devices. Very good at giving accurate colors and levels across the visible range, with little or no prejudice. Be sure any auto enhancements are turned off. Make a test print of the Kodak girl, and once again check the sRGB levels in the gray circle or the “139" tablet step. Same density. In the world of perfection, the hovering RGB data will be 139, 139, 139.
Oh, it’s not? Imagine that! Let’s pretend the numbers are 139, 101, and 151. That means the Red is spot on, the Green is weak, and the Blue is too strong. Since the Red is good, I’d bump the green by reducing magenta, and add yellow to bring the blue back into line. I sure wouldn’t worry about any numerical differences under ten, but YOCDMMV. (Your OCD Mileage May Vary.)
(Red is counter to Cyan, Green is to Magenta, Blue is to Yellow. Since all printers are subtractive, that means when you want to boost a given color, you subtract its compliment. And vice versa.)
There are two more criteria that you may choose to work with. Um, customize. One is Contrast. Increasing contrast will undo your hard work to get even densities, but for a given print, it may be what you want! The other is Saturation, what Canon calls "Intensity." You can have an image that has perfect RGB balance, but lacks color. It's weak and washed out. Bump the saturation. Er, Intensity.
So, experiment, and when you are happy (or attain “Good Enough”,) save that profile! Don't forget, no art exhibit ever had two similar prints sides by side to compare them! The eye/brain interface can adjust for a lot of objective sins! Stare at the color side of the Kodak portrait test image and then look at the monochrome. You will see an opposite hue in the B&W for a second! The reddish skin tone will be seen as cyan/green!
You can also get a double sided multi-colored “gray” card like this: http://www.ebay.com/itm/Pro-Photo-1...330?pt=LH_DefaultDomain_0&hash=item232a39f772 (If link is dead, just eBay search for “18% Gray Card,” and find the ones that are 5x7 inches with white, gray, black, and CMY on the front, and gray on the back.)
Do NOT use a scan of this or any other card and then figure “That’s black,” and “That’s white.” They ain’t, being reflective materials. They can never attain 0 or 255.
PHILOSOPHY:
ON TO COLOR:
