Robin-Whittle
- Jun 30, 2010
I have had good experiences with the toner from the Printer Ink Warehouse:
http://www.ink-refills-ink.com/printer/Brother+HL-5250DN+Toner/5748/
As per their instructions, I found it is necessary to remove the original toner as much as possible before inserting the new toner. I did this by dismantling the cart to the point of having the roller removed, and then vacuuming that area, and also vacuuming out the toner chamber via the fill-plug.
It is my impression that a full 250gm bottle of toner is too much for these carts. Maybe best to use about half and then use the other half when that runs out.
It is my impression that the carts can be refilled a few times. After a while, they may start leaking toner and so require frequent removing and vacuuming. This is bad, since I think the excessive toner causes the drum to degenerate faster - but that can be cleaned . . .
I will write in another article about the success I had with cleaning the drum of this printer.
BTW, I have had *excellent* experiences with the HL-5250DN. I normally run it at 1200 DPI resolution just to slow it down. This gives less paper curl. It runs from the Ethernet and I print directly to it from various Windoze computers. It is reasonably quiet and the fans turn off promptly. The print quality is excellent, and I am on 72k pages, most of that on the one drum, after more than 3 years. It can print duplex (on both sides), but I don't use this.
This printer is so inexpensive that I don't worry about it. My previous $1000 laser printer was a Kyocera, which worked OK except it needed cleaning frequently. Once, while cleaning it, I dropped a screwdriver on the drum and then found the new drum was $600 (Australian dollars). I then bought the Brother HL-5250DN for about $360 or so, and it has been brilliant. (Before that, from 1991 for about 10 years, I had a 300DPI $4k Epson EPL-7500 - so I have observed great progress in this field.)
- Robin
- Robin
