Pity , I was hoping that my suspicion was correct , now after reading your trials and tribulations with the "wrong batch" of ink in another thread , Im not so sure.
This is what i would do,
Firstly try printing your test picture at a Standard paper setting , (this will not use the Photo black , just the PG Black and see how it looks. If its good then the photo Black is probably a problem. Why ? It`s problem could be its getting contaminated within the printhead in the area I mentioned before.
To help establish this buy a new Photo Black and see if the problem remains after installing it.
or
Get hold of a set of Canon inks that have not been refilled , that is with some ink in and intact , if not from a friend , then buy a new set.
Ater installing, carry out a few cleaning cycles to work thru the old inks thru the head......and see how it looks. Print at Standard , Photo , High Res and see how it looks
if all else fails :-
The solution that should work is replacement of the head..........but I reckon you can probably replace the entire printer more cheaply. The head can be dismantled down to the rubber gasket but in my experience it is rare to re-seat it and solve the problem, hardly worth the effort.
I had a printer that was "off" when printing Photo...........but it was pretty good when set at High Res..........I kept it going quite a time that way.......not ideal but it was better than nothing.
Please let us know, ( if possible ) , how it proceeds dont let the System beat you.
