My Canon i560 has started to squeak each time it prints a sheet of paper. It squeaks as the paper comes through. Sounds like lubrication is needed but I don't know where to lube or what type lube to use. Is diassembly required? Help please.
If you do need more lubrication, your best bet is to find the squeaky area and see what kind of lubrication exists there and maybe spread some residual lubrication around. But you'll probably have to take the cover off the printer and this could be a lot of work if you don't have instructions.
