SpyderPrint
knowing
Print Lurker
HP CLJ5550, Brother MFC-9460
Hi all,
Ok, I have several questions below, so I hope someone is patient with me and can answer. Thanks for any feedback.
A Year back I went for buying a SpiderX Studio suitcase with SpyderX Elite and SpyderPrint scanner. Only later I read a lot of negative tings about the Datacolor products, on this forum and others, however, most of those posts are quite old, more than 10-13 years ago.
Has anyone tested if the later products have the same issues as the older colorimeters / spectrometers?
Some of the problems, if I understood correctly, was that Datacolor has implemented some proprietary black level compensation that is always on, and that when editing images in photoshop for softproofing one must use saturation intent and no black level compensation. Then also som issues with reading color patches correctly when reading per line, and not patch by patch.
I was not really satisfied with the result of the profiles I got, so I started looking around, because I might have missed something. I started playing around with ArgyllCMS, which was fascinating, and wonder why the SpyderPrint spectrometer is not supported as hardware that can be used with ArgyllCMS? I saw old posts 13 year ago where one was working on a driver.
I imagine that most of the problems with Datacolor is in the software, and the spectrometer itself could be used regardless?
The older extensive tests done, comparing the spyderprint and i1 (dont exacly remember the product names) showed that reading patches correctly could give good readings. Personally, I found the ruler board (SpyderGuide) making scanning more difficult and causing misreadings, but when I only used the board as a ruler to lean the spectrometer against the edge, then it went much smoother to scan patches. Also, the the paper I used, like copy paper or similar, to make a profile for, then I had to use several layers of A3 paper underneath to prevent color influence from the table underneath.
But what is required for creating such a driver to use the spectrometer? a (USB comunication monitor should reveal what happens).
Are there Hardware issues preventing this?
Also, I have speculated, like some others I read on forums, If I can scan with SpyderPrint, export the readings, and then use them in ArgyllCMS for making a profile? Is there a point to do this? F.ex. do one avoid the incorrect use of intent and black level compensation issues on Datacolor profiles this way? It all seems a bit inflexible and locked to Datacolor software and processes.
Or is it better to just sell the SpiderX Studio suitcase and get a colormunki for both screen and printer calibration? Or other product not too expensive?
Thanks,
Cheers,
K
You are right that Datacolor products have been updated over time; I'm not familiar anymore with the latest version of their pakcages; I'm irritated how Datacolor calls the Color sensor a 'Spectrocolorimeter' - what is it - a colorimeter measuring the intensity in a particular color range or a spectrometer measuring the complete color spectrum in 5 or 10 nanometer distance.
This page and other postings use this Spectrocolorimeter name for the measuring device
https://www.datacolor.com/spyder/de/produkte/spyder-print/
When you look here
https://media.distrelec.com/Web/Downloads/_m/an/SDSSR40DRVP_ger_man.pdf
you find an explanation for the full spectrum color sensor here -
Vollspektrum-Farbsensor
Die sieben patentierten, das ganze Spektrum abdeckende Farbsensoren von Spyder4ELITE übertrifft
Farbmessgeräte mit 3-Kanal-RGB-Sensoren. Jede Spyder4ELITE-Einheit wird im Werk individuell
abgestimmt, damit alle Monitor-Bauarten optimal adaptiert und korrigiert werden.'
It is specified here that seven - not 3 - RGB - color ranges are measured which may explain the
name Spectrocolorimeter.
But when you go down to page 5 the product package just contains a colorimeter and not a
....spectrometer .
' Lieferumfang
• Datacolor Spyder4ELITE™ -Colorimeter '
Older postings covered issues that the BPC - black point compensation function - cannot be used
on Spyderprint profiles and that the perceptual rendering intent delivered a wrong black point other than the rel. col. rendering intent. And various scans by forum members delivered completely wrong gamuts and deformed color spaces. When you get such results you are not coming back to such a product even some years later.
I think you are better off with products like the i1Profiler/Calibrite/ColorMunki packages or with the ArgyllCMS freeware if you can become familiar with its command line interface. A very affordable spectrometer has been identified from China which runs together with ArgyllCMS. You find several current threads running if you search for 'CR30' which is the budget level spectro from China.
https://en.chnspec.com/Product/info.aspx?itemid=441&lcid=246&id=228
It is a spectrometer although it is called 'Colorimeter' by the seller which is probably a translation error from Chinese to English.
