Something to consider if buying an Epson printer...
Andrew2468
Yesterday I contacted Epson Europe to see about getting my R2400 serviced, I can't get a clear nozzle check. I don't use Epson ink. They will not service the printer unless I buy and install a set of genuine carts!
It was an online chat session and here is the transcript (with the name of the Epson guy hidden and my name changed to "Me")
11:36:34 : Connected to etalk.epson-europe.com
11:36:34 : Session ID: 1327288
11:36:34 : Me: Initial Question/Comment: I have an R2400 printer and can't get a clear nozzle check. I'm wondering if it needs a service. Please can you give me (or email me) contact details for approved servicing in Xxxxxxx UK. thanks Me
11:36:39 : System: Epson rep has joined this session!
11:36:39 : Epson rep: Thank you for contacting Epson's UK Customer Interaction Centre. My name is Epson rep
11:37:25 : Me: hi
11:37:54 : Epson rep: Hi Me. One moment please.
11:39:29 : Epson rep: We offer a fixed price repair service directly from ourselves for this printer. Are you using Epson inks?
11:40:58 : Me: Not at present. Does that matter?
11:41:55 : Epson rep: Yes we would need Epson inks in the printer to carry out a service, has the printer been modified in any way, such as a continuous ink system?
11:43:48 : Me: It's not been modified. Why would I need epson ink if the printer is going to be cleaned? - that's a substantial cost to me!
11:45:10 : Epson rep: For a engineer to fully service the printer and ensure the printer functions correctly we would need Epson inks installed as we cannot guarantee the use of non genuine inks.
11:51:29 : Me: Can we come to some compromise here maybe? I'm fairly confident the ink is ok - Jon Cone ink - and the printer has been working fine with it until this last few days. Would it be possible for Epson to carry out the normal servicing and if a clear nozzle check still did not result, then I would accept that (and pay the fixed price of course).
11:57:21 : Epson rep: Ok we would need to diagnose there is a fault with the printer by having the Epson ink cartridges installed as this is part of diagnostics
11:58:01 : Epson rep: We can't carry out the service without the Epson inks installed first
12:01:06 : Me: That's rather restrictive. What part of the servicing needs epson ink rather than any other ink, please?
12:04:42 : Epson rep: Having the Epson inks will help diagnose the issue, Epson inks contain cleaning agents to help unblock the nozzles in the print head
12:05:02 : Epson rep: Epson cannot guarantee the viscosity of non-genuine Epson ink as it may be thicker and over a period of time this may cause the fine nozzles in the print head to become blocked which could cause possible head damage.
12:11:58 : Me: I appreciate epson can't speak for other people's ink, but I'm not asking you to guarantee anything. I just want it cleaned. Please can you give me the fixed price amount and let me contact whoever does the servicing.
12:13:58 : Epson rep: We would book this for you but would need to run through full diagnostics first of all by having the Epson inks installed. You can try contacting Equinox service centre to see if they can provide a service for you on 01684 853116.
12:20:52 : Me: Thanks for the phone no. Re. insistence on epson ink for epson servicing, please can you escalate this to an epson customer relations manager. I have paid for a custom colour profile for my ink, so putting epson ink in is likely to mess things up. It is very restrictive of you to refuse servicing just because the ink is not epson. I don't have approx 100 just lying around to spend on ink I don't need or want. You haven't given any valid reason why you can't service it with my ink (or no ink at all if you can use flush fluid. Please record this as a complaint.
12:29:49 : Epson rep: I have spoken with my supervisor and I would recommend contacting Equinox directly as we do not encourage the use of non genuine or services with the non genuine ink cartridges
12:33:13 : Me: I'd still like this raised as a complaint please, on the grounds that it is an unfairly restrictive policy. If I took my car for service at the dealer, having put someone else's tyres on it, I would not expect them to refuse to service it. Do you have a problem logging this as a complaint?
12:35:35 : Epson rep: I have passed on your comments and my supervisor is fully aware of the situation however this does not change the service that we provide
12:40:15 : Me: Or to be precise, the service you don't provide. I think that wraps it up. Very disappointing. Bye.
--- end ---
Andrew UK
Here's the odd thing.
When returning printers to Epson on warranty, they request you remove the cartridges prior to shipping and even go on to suggest that you can reuse the cartridges. This contradicts known good advice to keeping cartridges in to prevent serious drying problems.
What can you surmise from this?
I would venture to guess that in fact they do not clear the printhead but rather simply replace it and enter the printhead voltage parameters. On their side, the replacement is far less costly than servicing the head. After they have cleared or rather replaced the printhead they will probably return the printer to you with a new set of full cartridges. This replacement of head is possibly standard routine with all returning printers and this could explain their non requirement of cartridges installed.
If you're looking for a partially empty set of virgin R2400 cartridges to proceed, just to enable a return, please contact me. The cost will be reasonable and I ship to the UK. The 2400 is too capable a printer to be trashed if the printhead replacement (or servicing) is reasonable.
