Samsung CLX-6260ND print alignment
David R
Samsung CLX-6260ND
Hi guys. The above printer is fine in monochrome but when printing color is way out of line.
I have used the in-built alignment tool without success
I've cleaned the print carts and changed them (although from compatible to compatible)
I have turned printer off, removed carts, turned printer on and then re-installed carts.
No luck.
Any ideas what is wrong?
David R
Samsung CLX-6260ND
Unfortunately, no real guidance on mis-alignment - tells you to go to tech menu, but can't see what to do from there.
Thanx for answering though
