refilling cli-8pm and some others Cannon Pro 9000II
Darth said:
Unfortunately now the adapter came loose from the clip. So I have to wait for the new one or try to glue this one back on.
I tried epoxy and then cyanoacrylate, both without success. Don't know what Octoinkjet used.
Before any of these purge clips were made and sold this is what I used,
it was made up using Araldite epoxy adhesive and a hard plastic washer for extra strength and is still working.
http://www.nifty-stuff.com/forum/viewtopic.php?pid=59370#p59370
Darth
ThrillaMozilla said:
Darth said:
Unfortunately now the adapter came loose from the clip. So I have to wait for the new one or try to glue this one back on. I tried epoxy and then cyanoacrylate, both without success.
Just use this.
http://www.nifty-stuff.com/forum/uploads/7413_filladapter.jpg
It's just tubing stuck together with a little epoxy for good measure. You won't need the bend for purging. Just suck deionized or distilled water through the vent, and it will clean out the sponge nicely.
I had the purging clip from Octoinkjet which came loose.
Darth
Just use this.
What makes Araldite any better than JB Weld? Although I admit that I used the 5min version.
You have to use the 90 minute version of Araldite, thats the good one.. :)
