wcandrews@sccoast.net
- Nov 29, 2010
I've had great success in filling BCI-6 carts for a Canon i9900 printer. After I purchased a Canon Pro9000 MK II with CLI-8 carts, I looked for refill options. The chip on the CLI-8 generated a lot of problems.
I had great success with BCI-6 carts and Media Street Plug and Play ink. Ink2Image took over from Media Street and offered virgin carts to replace the Canon CLI-8 carts. This was familiar ground for me, and I purchased a supply of their ink and virgin carts.
The ink works well, but the carts are a different issue. The carts have given a continuing problem. Although you can get a good nozzle check, the prints show banding that suggests cart ink starvation. This conclusion is supported by the fact that replacing the Ink2Image carts with OEM carts eliminates the problem
Calls to Ink2Image were most unsatisfactory. They have no interest in working through this problem. Their only solution was for me to purchase a set of new set of carts. I'll not do that now -- I've already done that and it didn't help.
All of this means that I have come to the conclusion that the recommendations on this forum to refill original Canon OEM carts is the only real solution.
1. I have decided that the "German Method" is the way to start, and the refilling operations give me no problem. But I do have some issues:
2. I am a color managed guy. I want the colors on the print to be like the colors on the screen. I've have spent a lot of money to get this to work. I have xRite hardware and software to produce correct profiles for my complete work flow from camera to monitor to print.
3. To get the desired results, it seems that one should start with a "purged Canon OEM cart."
3.1 Can they be bought?
3.2 If they can't be bought, how do you purge the existing Canon OEM cart so you can make a proper profile with the the new, non Canon, ink?
Thanks!
Wil
Thanks!
Wil
