3dogs
- May 13, 2012
- Location
- Fern Hill, Australia
- Epson 3880. Canon Pro 9000,
Most often I only refill one cart at a time, this time I elected to do ALL at once prompted by the OEM PK cart finally reaching empty after two years of printer use.
On completion I did a basic menu manual nozzle check to confirm that the printer had returned to full service. VM showed MANY fail to fire nozzles, around 15-20%! I am stunned, assumption no.1 was existing ink in the supply lines would be good (no air bubbles) and no.2 that the nozzle check would only tell me that the entire colour was A OK, not individual nozzle performance, that I thought would not show up till ALL the existing ink in the lines had purged. ARE THESE ASSUMPTIONS CORRECT?
OR>>>IS THIS PAR FOR THE COURSE WITH REFILLING - JUST ANOTHER DAY AT THE OFFICE??
My workflow
Gently, agitate ink supply bottle ( pigment ink) and cart, refill, check weigh for correct volume and reinstall. Once refilling is completed, close cover and allow the printer to return to PRINT ready status.
As soon as its back on line run a nozzle check. (SHOULD I BE WAITING ??? HOURS BEFORE DOING THIS?
This is the second time VM has presented with 15-20% misfire in a month. Once cleared 100%, or so it has been in the past!!
Cheers,
Andrew
My workflow
Cheers,
Andrew
