Program for HUB printables. iP 4500
gotloveforall
Hiya folks! :-D
Now that I have my iP 4500 setup I found out that I can't use Canons CD-LabelPrint software to print on HUB-printable dvds.Any way to work around that?
Or any other software recommendations that will do the job?
My crappy Ridata hub-printables are going to waste. :lol:
jflan
Vancouver, Washington
gotloveforall said:
Hiya folks! :-D
Now CD-LabelPrint has a built-in outer limit of 118mm, but there should be no problem adjusting the inner diameter of a hub-printable disk.
Have you tried the following ?
http://club.cdfreaks.com/1727256-post43.html
Kefp
San Diego, CA
TS9020, Pro100
Open CD-Labelprint>File>Select paper>new
Then adjust away and save. My Sony Hub printable's inner circle is set at 24mm.
