I purchased refillable carts awhile back on ebay. I've been using them for more than a year, but I'm facing a problem with the black cartridge. Whenever the printer is in idle or turned off for more than an hour, the black color leaves streak marks. I have to run one or two cleaning cycles every time. Upon suggestion, I primed the cartridge by placing a rubber stopper in the air vent, and putting a syringe (without needle of course), and pulling the syringe and letting it go to it's natural position. I did this a couple of times (four - five times), although it did certainly help, the next day same problem occurred again. There were streak marks in the print. Everything is usually dandy after preforming a cleaning cycle. This in result has left me with ALOT of waste ink. Any suggestions??? The black ink port does not seem to be clogged, I have already cleaning it out be using an empty cart with a cleaning solution in it,,,,
