Pro 1 only printing some of image
GaryJay
Canon Pro 1
Started my Pro 1 after a month and a half of hospital stay. Printing the collage I downloaded from JToolman site to check printer. Printing in Lr and Ps,both with printer manages colour settings and all settings correct for this process. Use OEM inks and carts, for this I was using Canon Pro Lustre A4 and A3 paper. The printer stops printing part way through the print and ejects the print,it then goes through the feed process again as if I had a number of images to print, it only stops when I cancel printing in Lr or Ps.Photo attached.
GaryJay
Canon Pro 1
I have had printer for at least 41/2 years.
@GaryJay, The problem you describe is much like a communication error (Interruption of data), between computer / printer while the printer was printing, because the printer couldn’t finish the print, it may have tried to complete the process again....
I wish you continued good health my friend.. ;)
GaryJay
Canon Pro 1
Do you think that might be a cable prob from computer to printer, I use the USB 2.0 connection
Most USB cable connections are rugged and reliable, but a quick check is always advisable, if the computer is not a suspect, a split-second mains power glitch can also affect data transmission, the best thing to do is to try the same print again, using the same App. .. But it may have been just a one-off thing..
