Precision Color PC25XSE yellow
ksuttonphoto
Canon ip8720
Does the precision color PC25XSE inkset yellow have a jelling issue when mixed with oem ink?
I've read that some of their other inksets do ?
bluestang
NE Ohio
Canon Pro-100, EpsonArtisan730
Says nowhere on PC's website about a yellow jello issue..
https://www.precisioncolors.com/C6Eb.html
One would be under a safe assumption that it hasn't happened. Of course, I'm no expert either. Just been doing research lately for an old Epson printer I got and browsing/reading the PC website alot.
ksuttonphoto
Canon ip8720
Thanks 😊
AFAIK, Yello Gello may happen with any refill ink brand when used in specific OEM Canon cartridge ink sets. At least that is the forum consensus caution.
Ask forum member mikling who owns Precision Colors here or via his web site. Who better to tell you if a risk occurs with his inks.
The solution is to either only use OEM inks in the potentially affected cartridges (ie only OEM Yellow), use a different model cartridge, such as a CLI-9 instead of the CLI-42 (swapping over the chips), or thoroughly flushing out the OEM Canon cartridge before refilling.
https://www.printerknowledge.com/th...estions-on-cli-251-printers.11587/#post-97508
Tested over a year with no gelling in two printers. So PC25XSE yellow is clear of the issue.
Still testing the PC42SE yellow on the Pro-100 and after multiple tests over a long period, the results lean towards the elimination of the gelling issue. However on the side of caution, I am still advising to treat as if it will until further notice or further tests are completed. The confidence level increases each day until I am 99.99% sure it does not happen.
ksuttonphoto
Canon ip8720
Thank you for the info !
