jru
FYI:
I noticed that the optimal needle length for using the Durchstich refill method seems to be 50 mm (a little less than 2 inches).
This length allows you to push the needle fully in until the plastic base of the needle stops further entry, and this leaves the needle tip just short of hitting the optical sensor plastic....
So you don't have to guess whether your needle tip has "made it" into the spongeless chamber (past the wall that separates the sponged/spongeless chambers).
This seems especially helpful with the black inks cartridges, whose coated walls makes it hard to see where the needle tip has reached.
I think I got these 50 mm needles from hobbicolors (I'm not positive about that).
Allotofthings.com doesn't seem to carry 50 mm . Last I checked they had 1.5 inch then 2.5 inches.
http://www.alotofthings.com/viartshop/p amp;page=2
Compubiz.com doesn't either... They have 1.5 inches then 3.5 inches.
http://216.219.159.185/tools.html#anchor29689
Anyone know someone who sells 50 mm needles?
jru
jru
