- Oct 27, 2005
- Location
- South Yorks, UK
- Epson, Canon, HP... A "few"
Hey folks... I have an IP4500 which I'm taking the case off of so I can modify the case slightly to allow cartridge fitting clearance when I install a CIS.
I've worked out part of the deal which involves slightly lifting then sliding the two black plates at the back left/right of the printer to show two additional lugs that (with the the two obvious push points under the lid) allow the sides to be taken off.
Where I'm coming unstuck is working out where the remaining two lugs and push points are in the front segment of the printer to uncouple the main top body.
Anyone tried this yet and found the points needed?
Cheers
Cheers
