KCDoug
It's late, or maybe another senior moment, but I've been searching through posts and don't understand how to clean my i960's printhead. I've not printed with it for a few months. I recalled that when I last used it I got an initial warning that the yellow was low, but it was not out. So before beginning to print tonight, I replaced the yellow cartridge. I then aligned the printhead, all seemed normal. The first print had all the colors, but looked a little washed out. The subsequent print had yellowish skin tones, and colors were more noticeably washed out. I ran a cleaning, then ran a nozzle check. The Photo magenta was absent on the nozzle check pattern and some other colors were a little light, but otherwise okay (no banding or missing parts of color blocks). I attempted to print another pic - more yellow skin tones and washed out colors. Did one more clean and nozzle check, no change in the pattern. Did a deep clean and nozzle check, still no change in the nozzle pattern. Printed two more pictures, skin tones not as yellow, other colors still look washed out, though not as pronounced as couple preceding pics, and the clarity was slightly improved. But the pics still look pretty lame. My guess is that I should probably remove the printhead and try cleaning it.
I'm confused by what I'm reading here, and a search of the forum hasn't yielded the simplified explanation I was hoping to find.
I removed the cartridges and the printhead without a hitch (trial run), but without pictures/diagram, I'm unclear what is what that people reference when talking about soaking and about blowing out. I can see the rubber seals and the semi-hard pad-like material in the center that the cartridges seat on and the ink goes through, but how do I clean that area? Is that the area folks are saying to hold under a facet, or blowing air into? The underside/bottom of the printhead has a metal (copper?) plate, is that what folks are soaking in water or windex, or whatever? Or do you remove that plate and soak whatever is under it? And if you were using compressed air or a syringe to squirt fluid on the inside holes/ports with the rubber seal around them, wouldn't the metallic plate on the underside need to be removed first? Clearly I'm a bit confused or too simple-minded to figure out the obvious tonight. Any clarification/simplication will be much appreciated; I really don't want to spend $75+ for a new printhead. Gosh, I've probably only printed about 200 pics on this one! (I don't use it that heavily.)
Thanks,
-Doug
Thanks,
-Doug
