After powering printer up, it goes through the usual start up actions then it stops with the red ink error light on. Status monitor indicates all cartridges are OK. However, there is no sign of ink flowing through the printer head into the waste ink sponge under the carriage parking station.
This printer has not been in use for the past month or so. I've tried both old (but freshly reset) Epson OEM cartridges, as well as a CIS which was working well just before printer died. Even though the Epson OEM cartridges are old, I checking by weight & they appear to have ink in them. I've already put some cleaning fluid (Windex/alcohol) through the ink ports on the printer head using the syringe/rubber hose trick. Fluid went through the head OK.
Regardless, running cleaning cycles manually or the Status Monitor, or printing via software there is no movement any ink through the head. Although I don't understand exactly how they work, it almost seems like the head has lost it's prime so the peizo pump isn't able to pump ink - just air.
Does anyone have any ides how I might be able to get the ink moving through the head again?
Best regards, Richard
