avolanche
Hi,I just found this forum and it is great.I have read many,many posts.I have refilled in the past,but a lot of the info here is new to me.I have a canon MP780(BCi-6) that I plan to use with Hobbicolors cartridges/ink(will actually use the CLI-8 ink.I may also refill some OEM BCi-6 Canon empty cartridges.
My current head is in need of cleaning and I have some questions:
(1)Where does one purchase the clear vinyl tubing(both the larger 3/8" ID for flushing cartridges with water) and the smaller tubing(what size) for fitting over the inlets for each color to flush ink through the printhead?
(2)Where are nitrile "o"-rings available for sealing the screws used in the refill hole in the plastic cartridges(or will the Hobbicolors plastic screw suffice)?And what size is used?
(3)Is Windex with ammonia or alcohol still the preferred flushing solution?
Many thanks for answers! Fred
